Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
yes i it was over 85%, i guess that might be because of the charger pin as some times it starts charging. Like it was working fine for last few hours n stopped charging now. I need an expert opinion before getting it opened. As i need to confirm that the issue is with the charging port before opening
