THERMAL FUSES MAY BE THE CAUSE OF THIS In recent
years the makers of dryers are using thermal fuses to let you know something is wrong with
your dryer. They are generally non resetting and have to be replaced. The thermal fuses
are located on the heater element housing and should read
continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air
flow problems or a grounded
heating element. Follow the diagram below to see how to check the continuity of the switch, and look closely at the switch to see a fairly close idea of what you are looking for, ok
OR it could be a thermostat. Cycle and
safety thermostats-read them with an ohm meter. Should show
continuity .
or lastly, it might be the Heat elements-Test heater
element with an ohm meter. You will read continuity
across a good element ( 8-12 ohms is an average element ).
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
To check the thermal fuse - You can bypass the
thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass
the thermal cut-out (just connect the 2 wires together) for testing purposes
only.
To check the thermostats for continuity - -
You can bypass the thermostat (just connect the 2 wires together) for testing
purposes only.
To check the Element: Try removing element and
physically looking at the element wire for a break in the wire.
Do not forget to rate this answer!!
The
Kenmore 80 Series of dryers are consumer grade dryers for home use. As
with most home appliances, the Kenmore 80 series dryers will
occasionally not work as intended. If a problem occurs with your dryer,
however, you do not necessarily need it serviced by a technician. You
can attempt to troubleshoot and fix any problems with your dryer before
contacting a technician.
