Question about True Freezers
Freezer went into defrost mode friday evening about an hour later was showing a reasonable re freezing temp of -13 Monday morning freezer totally defrosted lost all of the food temp +13 Have checked compressor grid and it is free from all dust etc Do you think i need to get someone out to look at it
    Top Expert:
  • True Master
  • 63,714 Answers
Ofcourse you should have it checked or BUY A NEW ONE
Posted on Jan 10, 2018
SOURCE:
fridgetech
  • 473 Answers
SOURCE: whirlpool 10cube chest freezer red light
yes.
Posted on Oct 07, 2007
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
buddymcl777
  • 67 Answers
SOURCE: running continuously, food defrosting
Most likely you have lost your refrigerant in a leak, since the compressor is running but not cooling.
You need to unplug and get serviced or your compressor will overheat and fail which will be much more expensive.
Posted on May 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: freezer wont go into
Change the defrost control.
Posted on Feb 08, 2011
Why do i have ice on the freezer coil when the heater is working on defrost mode
Sounds like a fan problem. Have you checked the fans operate when the doors close?
May 06, 2012 | Freezers
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
My magic chef freezer will freeze for a day and then the temperature will increase to 70 degrees. The freezer is just two years old. Is it worth having someone to come out and look at it or is it...
This is a manual defrosting freezer so the most likely cause is the temp control. Sad that is is only 2 years old but the temp control is not working correctly.
It sure sounds like it is running until it cycles off at the "I reached the cold enough" SET TEMP then never starting up again. That start up is controlled by the temp control. Call and make SURE the temp control is called the thermostat!
1-888-775-0202
  • Available 7:30 a.m. to 7:00 p.m. central time, Monday - Friday
  • The Part number is WPF24B-L and the only source is Via this link: http://www.mcappliance.com/partorder.aspx
    List Price $22.95
    Thanks for choosing FixYa.
    Kelly
    Sep 05, 2010 | Magic Chef Chest Freezer MCCF5WBX
    Problems with an older Fisher Isotemp plus 98 model, the defrost circuit is not working correctly. The temp is normally around -20 degrees celsius and the temp is now at -08. I have manually defrosted the...
    Noah had one of these in the ark...he did a full defrost(left it for 24 hours with the doors open then cleaned the vents/drains)and his was fine after that,hope this works for you.....also check door seals for tight fit all round.
    Apr 06, 2010 | Fisher Scientific Freezer Isotemp* Plus...
    Freezer defrost cycle
    If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
    If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
    It is probably on the rear near the compressor. Some are under the front behind the dust guard.
    Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
    Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
    DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
    Feb 10, 2010 | Freezers
    Temp Alarm going off, when freezer seems to be cooling fine.
    You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
    Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
    The unit begins a defrost cycle without warning
    in general, a freezer will go into a defrost cycle about every 6 hours and usually from 25 to 40 minutes. After the defrost, the unit should function normal. Pull down to temp and cycle off. If the product shows signs of thawing, then I would be concerned about the box temp. Defrost may be too long or some other issue may be effecting it. Otherwise, if no signs of thawing, I wouldn't be too concerned. It's the product condition that is the concern.
    Nov 12, 2008 | Delfield 37.96 cu. ft. Commercial Freezer...
    Kenmore Freezer Temp. Alarm
    You should get a thermometer to be sure the temp is what it should be. With out it is very hard to tell correct temp.
    Aug 05, 2017 | Freezers
    Frigidaire Freezer Model FFU20F9FW1 defrost problems
    you say when you advance the defrost timer , id assume turn it ever so slightly the machine kicks on ad begins to freeze again?? then prior to advancing timer i would expect the unit to be totally dead(stuck in defrost mode).no fans,compressor or anything. that suonds like a bad timer or chck the wires going into the timer
    Mar 05, 2008 | Freezers
    Freezers Logo
    154 people viewed this question
    Top True Freezers Experts
    Dennis Boxerman
    Joe Palazola
    John Carter
    John Carter
    Level 1 Expert
    Are you a True Freezer Expert? Answer questions, earn points and help others
