Question about Disney Pirates of the Caribbean TV/DVD Combo
Code to program universal remote
I need a code to program a universal remote. I got the tv without the remote or manual. Tried using the Disney and Memorex codes to see if they would work, with no avail! HELP!
  • 1 more comment
  • callejero 50 Aug 04, 2008
    i bought tv\dvd piarates of the caribean but i do not have de remote control could you tell me how i can setting up a combo tv.
  • raggedyredd Aug 18, 2008
    We have the original remote, but even after replacing the batteries, we cannot get the remote to work. Without a working remote we cannot switch the "input" so that we can watch dvd's.
    So I've been looking for a universal remote code, or how to go about getting a replacement remote in order to utilize the tv to the the best of its ability.
  • Trudy Gunn Aug 21, 2013
    have extra remote for tv dvdcombo fordisney mickey and hello kitty tv
You can select between tv, AV, dvd using the buttons on the front (second from the left I think)
Posted on Aug 25, 2008
6ya staff
SOURCE:
Disney princess tv remote code
If you have the remote for the Disney Princess TV, it should control the TV without any code entry. If you are attempting to control the TV with a universal remote, you will have to use its code search feature to find a suitable code that will control some or all of the TV functions. Remember that codes are stored in the remote; the TV does not transmit them.
May 16, 2014 | Disney Televison & Video
Lost remote need code for universal remote
since most of the disney TVs are manufactured by memorex company ..... from your universal remote control's manual check the codes for memorex brand & try it .... if you don't have manual for your universal remote then from this link http://www.remotecentral.com/features/remotes.htm identify your universal remote & in that check codes for memorex brand & try it .... while searching answer for your question i have found that many people have same problem that is code for universal remote ..... but they never got right answer ......... & also neither same original remote control nor equivalent remote control is available (spare ) ...... so in case if you don't get right code then consider selling of this TV & buying new tv ...........
Oct 28, 2011 | Disney Lightning McQueen TV
How do u program a rca universal remote to a disney tv???? All the codes **** and half the websites do too....
If you tried all of the codes and still nothing I suggest to have the control find it for you. Programming with code search on page 10 will help you with that. The only thing I do not know is the model number for the universal remote so the instructions may not be right on.
General Manual - http://support.radioshack.com/support_video/doc66/66871.pdf
May 07, 2011 | Disney DT1350-P 13" TV
Same problem as above.Disney p1310ATV lost the remote. No Phone # in orginial manual.Television system NTSC (American TV Standard) I have tried other universal remotes also I have a Sony RM-V210 universal...
there may be a problem with the tvs remote sensor. most universal remotes you dont even have to enter any codes you just have to follow the same steps to enter the code but instead of entering a code all you have to do is press the channel up button after following all other steps, just keep pressing up until it turns the channel on the tv then press enter or similar button after it changes the channel and this should lock in the code without entering a specific code.And if all other remotes only half the buttons work on if it happens with every universal remotes then it probably a problem with the remote sensor or the tv . Good luck too ya!!!
Jan 02, 2011 | Disney 13" TV
Need Remote code for Disney Cars TV
I use code 759 with my Dish Network remote.
Jul 26, 2009 | Disney 13" TV
I NEED A PROGRAM CODE FOR A DISNEY TV
I had the same problem I used code 10463 and it worked...My daughter has a Disney Princess TV model DT1350P. Hope this helps.
Jul 12, 2009 | One For All URC-6131 Remote Control
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Universa remote codes.
Spoke with Starlight Marketing Ltd today who represent Disney. They said there is no codes for the Disney TV's. They have been trying to find out what the code is but since it is a private brand tv it does not have a code for a different remote. As I stated we bought the Pirates of the Carribean TV/DVD. My husband was fooling around with the remote and punched in 0216 and the remote read the code. The person from Disney said we just got lucky. Said that there were no universal remotes that would work with these TV's. This code was also used by the Haier brand tv. Hope this info helps anyone with a Disney TV. If you have any questions, you could e-mail me at jjrusek@bellsouth.net
Jun 12, 2008 | Televison & Video
I used Memorex code 135
Jan 20, 2008 | Disney DT1350-P 13" TV
Disney Pirates of the Caribbean TV/DVD Combo Logo
851 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Dalynn Turner
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
