Amazon Kindle 3G Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kindle will not start up even though it has battery charge. Is there a soft reboot?
MiB8888
Level 3:
  • Master 457 Answers
  • Posted on Jan 25, 2011
MiB8888
Master
Level 3:
Answers
457
Questions
Helped
274012
Points
1430
Yes:
  1. Get a watch with a hand for the seconds.
  2. Slide and hold the power switch for 7 seconds. After about 5 seconds the power light flashes three times. After 7 seconds, the screen will go blank and the device is switched off now. Release the switch.
  3. Slide and hold the power switch for 15 seconds (no more, no less). Do not hold the switch too long, the time window for the reset is not very big.
  4. After releasing the switch just wait. The Kindle will reboot after a few seconds.
Important tips to fix the problem of Kindle Fire won't turn on?
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
SOLVED: My kindle won't turn on. Is it the battery? - Kindle ...
How to Fix a Kindle Fire That Won't Turn On - Lifewire
www.lifewire.com > kindle-fire-wont-turn-on-or-charg...
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Amazon Fire Won't Start - Technipages
www.technipages.com > amazon-fire-wont-start
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
VIDEOS
https://www.google.com/search?q=Kindle+Fire+won%27t+turn+on
2answers
I was reading a novel on my kindle when the screen froze up. I tried to reboot by holding the off button for one minute, to no avail. What do I do now?
Suggest to be sure your Kindle is charged up. There are several generations of these devices. Search for reboot procedure online for example ... "reboot kindle 3rd generation".
1helpful
After update and fully charging, unable to connect even after restarting as instructed
Hard and Soft Reset
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
2answers
Why won't my Kindle Touch charge?
The Kindle touch are great devices for you reading needs. However, there are times when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding. hard and soft reset
  • Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.this might help you..
1helpful
2answers
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
  • this might help you.
1helpful
2answers
My kindle is frozen it wont let me search for new books
The Kindle touch and the Kindle FIre are great devices for you reading needs. However, there are time when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose you data during the reset process, make sure you have made a backup of your files before proceding.
Hard and Soft Reset
  • Your kindle should be back to a responsive state. hope this helps
2answers
My Kindle won't turn on after I charged it. I charged it because the 2 books I bought did not show on the kindle.
Hard and Soft Reset
2answers
My kindle light won't turn on to awake and when I tried to plug in to charge,no light came on.
If the charge light won't even come on then it sounds like you have a dead battery in your kindle and need to replace it.
Call support and order a new battery.
http://www.amazon.com/gp/help/customer/display.html?ie=UTF8&nodeId=200212360
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
