Televison & Video Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kde-50xs955 sony plasma tv and now hdmi port stopped working. tried with new hdmi cables but no luck. cut power to reboot still not working. tried different devices and wont show it is even connected to hdmi
Anonymous
Level 3:
Genius:
  • Master 1,112 Answers
  • Posted on Jan 24, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1112
Questions
Helped
263815
Points
3105
HI:
You need to replace the analog board assembly, this is the board that you plug connections into, seems the HDMI port has malfunctioned, there may also be a problem with the main board assembly that the analog board connects to.
Shuts off in 10 sec
mayble the ir remote panel at the back
Pink Screen
check all your cables & connections & connections at I/O ports; possibly I/O PCB
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
My plasma TV is not getting a signal from the hdmi cables. They worked earlier today and I have not changed them. The game system is the only component functioning now.
Tries tv unplug,replug it back like about hour later.For the tv do a resetting itself,take out the tv HDMI cable out the old HDMI hub port try plug it into another tv HDMI hub port.Should work now,still have same problems,probally needed a new HDMI cable replacement,the old HDMI cable is worn out or shorted out.
1helpful
I do not have a remote. Will a universal work?
Yes a universal will work for the TV. You will not have all the funtions with a universal though. You should be able to order a new remote from the manufature though.
Good Luck
My component cable is not showing any video.
it is a a/v hook up not a component hook up
try that like av1 av2 av3
should work a lot better
ron
5answers
4 BLINKS ON KDE-50XS955 ... WHAT COMPONENTS IN WAHT PART SHOULD I REPLACE?
4 blinks means Digital 5Vdc output voltage excessive or
too low.
Usually the power board. Also possible because of an abnormal power draw from B Board.
Test the following:
Power Supply Output Test CN1/pin 9 / 10
B board is the load - Test CN101.
To identify parts and components purchase service manual and follow schematics on service manual.
Parts and service manuals can be purchased from one of the following:
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Manuals and schematics.
ManualsParadise.com The best source of repair manuals
Replacement Parts: Plasma TVs, LCD TVs, Appliances | ShopJimmy
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
2answers
Tv prob
There is a sleep setting, similar to a snooze butting on an alarm clock, and it can be found in the Time Menu.  Just turn it off, and the set should work fine.
Good luck.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
