Hi, You cannot send
messages because the message centre number stored in your mobile may be wrong. Please enter the
correct message centre number. To get the correct message centre number please
call your service provider and they will provide you the number. Menu >
Messaging >Options >Settings > Text message >Message centres Thank You
SOURCE: text messages
Make sure you have a signal before you send the text and make sure you only have the phone number listed.
SOURCE: Not able to send message
First you haved to format your unit and your memory card,by formatting your unit pls follow this simple step,press # *7370# you have to enter your 5 digit security code the default code is 12345. by following this procedure will solve all your problem,especially is WD2 series .hope it will help........
SOURCE: unable to send text messages
Generally if the phone is giving a "cannot send" or "message failed" error message then there is something wrong with the "switch" In order to fix this you need to contact your providers tech support and they should be able to fix the issue...
You can also try sending the picture to your own number... sometimes that will help push it through the switch...
Also make sure that you are using the area code of the numbers that you are sending it to...
Alltel for example, will not let the message go through if the area code is not inserted
SOURCE: Unable to text
problem is still there after confirmation of message centre number.
I think the only solution for this problem is to reinstall the software coz this particular problem in N73 is a common one. So am also about to reinstall the software.
SOURCE: can't send text message. "unable to send message"
check your message centre number..If its edited or deleted..u cant send or receive any messages..contact your operator for tat number..
