SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
SOURCE: problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
