Sony Playstation 3 (PS3) Console Logo
Posted on Jan 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to copy a movie (previously copied onto my ps3 via memory pen) from my ps3 to my windows 7 laptop. When i hit copy a message comes up saying "connect storage media at the save destination". I do not know what to do and i have tried putting a memory pen into a USB port on the ps3. Can you help?
Nikki Mclean
Level 2:
  • Expert 293 Answers
  • Posted on Jan 24, 2011
Nikki  Mclean
Expert
Level 2:
Answers
293
Questions
Helped
88104
Points
891
Hi fat_cheesy_b
When you insert your usb stick into the usb port you then go to the movie you would like to copy hit triangle copy then you need to find your usb stick in the list so you can transfer the movie to there..
So firstly you want to make sure your usb is big enough to transfer the movie on there around 2gb would be find...Then you insert your usb stick into ps3 turn your system on go to the movie you want to copy from your ps3 system hit triangle copy and your usb device should flash up on the screen for you to select...
If your usb stick isn't being displayed you need to convert it to fat file system which is easy to do you put your usb stick into your computer go to my computer right click on the usb stick and select format to fat file system that way the ps3 will recognize the device..Try this if you need more help please be sure to reply back and i will be happy t help you =) cheers nikki (Please rate my answer)
2answers
I am not able to remove disc protection
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Trouble Copying Single 7 Gb file to 8 Gb pen drive on OSX Tiger
When you try to copy it to the drive what happens? What error message do you get?
Hi, i've got a problem. I can't store a movie on
Hello. :)
Your pen is probably formatted with the FAT32 filesystem, there is a limit to how big of a file you can copy to it. If the file is over 3.5gb you cant copy it to the pen. What you need to is backup your 300 pictures, copy them to your computers hardrive and then format the USB pen. Follow these steps:
Plug in the usb pen-> Head to "My Computer"->Locate the usb pen->Right click it and hit "Format"->Choose "NTFS" in the "File system" tab->Quick format->Hit start->Done.
Hopes this helps. :)
Can I transfer my iPod photos to my ps3 system? If so how? Ive done clicked on every thing tryin to figure it out so, before I give up, can any one pleeease help :)
There are many ways in which you can put media onto your PS3, and although this is not a definitive guide on every single possible way, I will outline the most common ways one may put media onto your ps3!
*NOTE*
Im using the new Firmware, 1.90. I suggest you upgrade as well for maximum flexibility, and for consistency in this article.
I think that before showing you how to put media onto your PS3, you need to know what kind of files it will play, as only certain files can be played!
Pictures:
-JPEG (DCF 2.0/Exif 2.21 compliant)
-TIFF
-BMP
-GIF
-PNG
Music:
-Memory Stick Audio Format(ATRAC)
-MP3(MPEG-1/2 Audio Layer 3)
-MP4(MPEG-4 AAC)
-WAVE(Linear PCM)
*NOTE ON MUSIC*
If you have licenced MP3s, or any other kind of restricted material, then it most likely not play using the PS3s music software.
Video:
-Memory Stick Video Format
-MPEG-4 SP (AAC LC)
-H.264/MPEG-4 AVC Main Profile (AAC LC)
-MPEG-1 (MPEG Audio Layer 2)
-MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
-MPEG-2 TS (MPEG2 Audio Layer 2)
Copy using Device
Now that you know what kind of files the PS3 will play, it is safe to put them onto the PS3s HDD!
Transfering using a CD(Using Files), Memory Stick, Flash Drive(USB), SD Card External HDD*, iPod*, which will all be referred to as 'device':
It is important to know that you must(well, not sure if its a MUST, but it works better this way) have folder corresponding to what media you are transfering. For example, im going to transfer two songs, two pics, and two videos. So, on the device im using, I would make three different folders: Music, Pictures, Video. Understand? Great.
Now, once you have copied the media(files), and placed them into their corresponding folders, you can insert the device into the PS3. Switching to the PS3s OS(operating system), you can copy the media to your ps3 pretty easily, and its the same for pictures, music, and video. For my example I will use an SD Card as the device used to copy media:
Using anything but an external HDD or iPod:
1. Using the PS3 controller, find the appropriate tab (Music, Video, Photo).
2. Press the Down key until the device is shown. My device is a SD Card, so I will highlight it.
3. Press the triangle Button once it is highlighted, and select display all.
4. Press the X Button on the corresponding folder(Video for Videos, etc).
5. If copying more than 1 file, press the triangle button and press the up arrow on the controller until you highlight the 'Copy Multiple.' Press X. Now you can choose which media you wish to copy, or you can copy everything by pressing the right arrow, and choosing 'Select All' then Ok.
6. Watch as your media is copied to the PS3!
Using an iPod:
1. Locate the white USB cord that came with your iPod. In case you were wondering, thats also probably how you charge your iPod too. smile.gif
2. Connect the iPod to the PS3 using the USB Cord. Yes, you can do this.
3. Highlight the iPod using the controller, press Triangle. Then highlight display all and hit X.
4. Select iPod Control, Select the appropriate folder (music, Video, Pics), Hit X.
5. Hit the Triangle Button again, and select copy multiple. See step 5 above.
Using an HDD:
Ok, I admit, Ive never used an external HDD to copy anything to my PS3. But if you have read the steps above, I can almost guarantee you will have to hit Triangle, Display All, and then find where you put the stuff. Its important to be organized, so you should probably just have a folder that contains all music, all video, and all pics, broken down however way you like it. The steps to copy the media should all be the same as above. smile.gif
Copy using "Search for Media Servers"
Ok, this is a bit more complicated. The only way I know how to do this is using windows, so for everyone using linux, "Lawl." Im sure there are more ways to do this, im just showing you the way I figured it out. You *MUST* have a router to do this, or be on the same network as your PS3.
For demonstration purposes, I will use music for my example. This will also work with pictures and video
1. Transfer all media to the My Documents folder, and put them into the correct folders.
2. Load up PS3.
3. Goto Windows Media Player 11(If you dont have it, DL it), Library, then Media Sharing. Select "Unknown Device" and hit allow. **DO NOT** 'Allow new devices and computers automatically.' This will let any computer connect to yours, and probably will allow them to upload some nasty Virus'
4. Go back to your PS3, and now under Video, Music, or Picture tab and now select the thing with the Windows Icon. *Note: if there are more than one, then select the computer you want to retrieve your media from, ie yours.
5. Select Music. Hit X. Hit down until you highlight Folders, hit X. Goto my Music. If you wish to copy the whole folder, hit triangle and select copy multiple, the select all and copy. If you wish to only copy a few songs, select the My Music folder, hit x, then triangle, then highlight the song and hit copy.
Hi how do i connect my external hard drive to my ps3 and watch films
Step 1. Connect your storage device (I usually use a pen drive) to your computer
Step 2. Copy Movie to the storage device
Step 3. Eject storage device and connect to your ps3 via the USB port.
Step 4. under videos an option of your storage device should be there but do not choose X button instead press triangle for options, then select display all.
Step 6. Locate your movie and select it using X button.
Step 7. Enjoy the movie!!!! This works with MOST movie files, you may find problems watching some movie because of the way they were encoded.
Step 8. Done.
Good Luck
Hi, Am trying to bluetooth messages, pictures and videos from nokia 6720 classic to a toshiba laptop. Do not know what I'm doing wrong! My phone will not let me send or receive messages etc as it...
Copy your messages,pictures and videos through the usb cable and clear all your phone memory of it.After copying all this through your pc suite ,check the nokia exchange folder and copy the files on to your hard drive.
I installed win7pro. can't find ie nowhere. why?
If it was a cracked/pirate copy, try another version. You may just have a bad copy.
Try downloading firefox onto a pen drive then installing on that pc.
If it was a Full retail copy of windows, just try again, go into advanced settings on install and delete the previous partition/installation
Laptop powers on, but windows doesnt load
Boot PC from Windows XP installation CD you will be ask to instal fresh copy or repair existing installation - go for "fresh copy" software will analyze you PC and try to find your previous copy of Win XP you will be ask again to repair copy of your existing Windows Xp now go for "Repair" option so installation software restore all Windows files and will keep all your settings*.
This solution is only temporary because IE 7 and 8 will no longer work after restoring - backup all your data and instal fresh copy of Win XP after all and always keep Your Backup up to date!!
2answers
Copying Video ---- TO ---- my Canon A540
Yes, if you use a card reader, and do not change the file name, AND place the videos back in the same folder it should work.
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
