Question about Coleman 10' X 10' Sundome Tent 9160K101
MY COLEMAN ECHELON 9S HAS QUIT WORKING--When I took the cover off I noticed that the motor was humming. I moved the little fan inside manually and turned it back on-it worked for a brief second, stopped and started humming again. Is the motor bad or is there an object stuch in it maybe?
    Top Expert:
  • Coleman Master
  • 10,033 Answers
Bad motor
Posted on Sep 01, 2018
SOURCE:
SOURCE: 5000 watt coleman generator. Starts but no power.
engine starts & runs but no power.checked breakers ,theyre not tripped
Posted on Mar 01, 2010
  • 9 Answers
SOURCE: how do you get the inside fan motor cover off of a
grab it and pull straight up
Posted on Apr 01, 2010
  • 3417 Answers
SOURCE: coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Posted on Apr 27, 2010
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
  • 333 Answers
SOURCE: Coleman Powermate Air Compressor 4hp 11gal.
Make sure you are plugged direct. No extension cords
Posted on Jun 17, 2010
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Blower not working on hi
coil froze up or bad capacitor.
Jun 26, 2014 | Coleman Heating & Cooling
Unit stopped working so I took off the cover and found the fan not working so I pushed by my finger and its is running but very little air if coming out also I noticed no water dripping out the back. Could...
check the indoor fan motor by this method switch on the unit check whether the motor is running or not if not than simply move the blower clock wise direction if it start moving than replace the capacitor.
Jul 28, 2010 | Heating & Cooling
May 28, 2010 | Coleman Heating & Cooling
Coleman echelon 9.T furnace will not turn on. Red light blinking
Apr 27, 2010 | Coleman Propane Forced Air Heater...
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Sep 07, 2009 | Windchaser 3-way Oscillating Fan
Amana dryer not working and just humming
you need to replace the belt, it is slipping
Aug 07, 2009 | Amana NDE2335AY Electric Dryer
Coleman 5640 cooler
The cover on the inside just pulls off. Inside/Outside fans pull off. 2 screws to dismount motor. Unscrew leads to terminal. Most truckstops carry the motor, otherwise search for Colman 5640.
Jun 27, 2008 | Refrigerators
Coleman 10' X 10' Sundome Tent 9160K101 Logo
278 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
john h
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
