Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs:
Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of
vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That
is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa
11 on Windows 7 or other systems, you should first set to the
shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic
card that you are using. Check the drivers you are using for the video
card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process
out for the implementation. You can download the current new AMD
catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia
card.
4. Change the resolution to have a try. Some users get the E0001
error fixed for Fifa 11 by trying the 1280x1024 resolution on
his computer.
Hope this solution was helpful? Please comment for more information
and thank you for using fixya
SOURCE: when i try to run
You can try updating your graphic cards to the latest drivers from Manufacturer Site, update your DirectX to the lastest too. If you still get the errors, this means that your graphic card does not support the "Shader mode 3" to run Fifa 11. You have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps.
Error Message E0001 = This game requires a shader model 3 (or better) card.
You have to upgrade your current graphic card to a better one to run this software!
***Take note:-
The chipsets used in models NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300, ATI Radeon HD3200, HD4350 und Intel/S3 do not satisfy the hardware requirements
Hope it helps.
SOURCE: E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
SOURCE: when i start fifa 11
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Hope it helps
SOURCE: i cannot access my fifa
Error... E001 is due to your Grahpic card not supporting Layer 3 mode. You should get a better Graphic card to play the game!
FYI
ATI Radeon HD3200, HD4350 and
Hope it helps.
