https://www.ifixit.com/.../My+Phone+Keeps+turning+off+and+then... iFixitMotorla phones can do this with they have a problem with their boot loader or ... when iturn on my phone and it does its power up, i wait for my service to ... i dont know how to fix my phone it always goes off and on i will give 150$ if .... is turn itself on and offnever getting to the start screen. and it only does it if its plugged in.
mY Dear: First: restore your Phone Settings IF problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
mY Dear: First: restore your Phone Settings IF Restart problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
SAME! how strange but true it gets so annoying at times i always have to wait for 5 mins and then it comes back on. also with this phone it goes really slow and crashes! is not very good!!
Well, you can try this; Check the behavior of the phone with a new battery and see. A battery problem could cause this. If this does not work, then you would have to check if no key on the phone is stuck. But the second is not likely since a stuck key would cause a phone to freeze. If this does not solve it, then you would have to see a nearest mobile phone technician since it will be an internal problem on the main board which will require the hands of an experienced person. Thanks
hi
first pull out the memory stick then restrt the phone
it may hppen due to currpt file in your memory card
if problem is not solved by this then you have to need
reinstallation of your mobile softwere,problem will solved if
there is a no liqiud in yourhand set.
vyas
I BET YOU HAVE A LOT OF RING TONES AND PICTURES IN THE PHONE., THE MEMORY ON THE PHONE SUCKS. DELETE A FEW PIC AND TONES AND THAT WILL SOLVE YOUR PROBLEM.
this is always happenning in this type of sets.dnt worry.first of all install a gud antivirus software.if it is solved its ok or else format the mmc.and also the phone.the code is *#7780#
