I have a problem. When I was syncing my contacts of my iPhone with my Outlook contacts, the mobile and other numbers got stored in 'Notes" I manually put the numbers in their respective columns in excel sheet and reimported them to Outlook. The problem still persists.
Please help.
Regards,
Venkat
These are the manual methods to perform when Outlook not syncing. But these manual solutions may cause corruption in Outlook PST files which causes more issues. So, to repair them quickly and securely,
You can use third-party tools by which you can easily repair PST files quickly and hence, fixes Outlook sync errors. This tool helps you to fix any corrupted or damaged Outlook file. It also restores the large-sized Outlook file.
Read More: https://www.easytechtools.com/resolve-outlook-sync-issues-folders/
We are providing all support for outlook users, if any user getting technical issues during Microsoft outlook as account blocked problems, Issues in Composing Mail, receiving mail issue, forgot mail password, email problems on iPad, Unable to send, configuring e-mail etc. call us any time our toll-free microsoft outlook support phone number +1-888-964-8356.
Did you add the PC in trusted mode at your phone? Activate the contacts sync with your email which configured at the phone and add the same email account in your outlook. All contacts will be synced automatically.
SOURCE: change display of contacts to first name, last name in outlook 2003
You can also use the tool at http://www.SperrySoftware.com/Outlook/Contacts-Sort-Order.asp.
SOURCE: importing from excel
go to file in the outlook.
click on import and export
select import from another program of file, click next
select Microsoft Excel 97-2003, click next
type in or browser for the Excel file you want to import, and select don not import duplicate items. click next
select destination folder-contact folder click next
***********To add or remove fields to determine the way the contact information is saved in the new imported file,***********
click on map custom field.
click and drag the item in the left panel to the right panel, where you want the item to appear.
click finish.
if you don't like the way the items imported. just hight all of the items that was imported in the contact folder and press deleted.
you can start again.
if you still have problem. go to the follwoing link
http://office.microsoft.com/en-us/outlook/HA010964231033.aspx
SOURCE: Exchange Direct Push Only Working when Outlook is open
I have the exact same setup with diffrent BB and now HTC on the ATT 3G network and my HTC are sync when Outlook is open in real time. When Outlook is closed they sync but many hours later??? Real frustrating. Any idea would be great.
SOURCE: using microsoft xp and put my contacts in
Hi Eldonj125,
This is a common issue with the iphone. Now, while although it is easy to presume that the issue you ae facing might be due to Operating System Incompatibility (as you probably would've gussed by now), please try the following solution below to see if it helps resolve your situation:
Total outline of the solution:
How to do it:
Settings on I Tunes
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Regards,
Technomancer
