SOURCE: runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
SOURCE: chainsaw will run for 5 min then stalls out
Fuel is induced into the engine via the diaphram to the carburator. If the diaphram is weak or has a hole in it, it will run out of gas just like you discribed..
SOURCE: Engine only runs when choke is on, then it stalls.
I would check carburator for plugged jet. Remove float bowel and check them. You will need to clamp off fuel line when you do this
SOURCE: Spark Plug for Briggs & Stratton Engine
you'll need a champion J19LM [or RJ19LM, same plug except the RJ is a resistor plug]
SOURCE: i got a husqvarna 371xp it starts but when i give
Have you changed the ignition unit? Have you removed the starter cover and checked the Woodruf key for slippage?
Lou
