When I plug my ipod into my computer, it doesn't show up anywhere. Neither in "My Computer" or itunes. I'm running Windows XP Professional. I've tried resetting and forcing it to disk mode, reinstalling itunes, changed USB ports, and all the other possible solutions offered by the help web site. It was suggested that I take it to an Apple store for repair. It still plays music and videos that are downloaded on it, it just won't sync up with itunes.I have more music and videos that I wish to install on it. ipod wont charge or sync with computer. i bought a wall charger and it still wont charge. any advice is helpful but i would prefer not to have to return the ipod. i dont care about the music on it or anything and just want it to work.
I had the same problem. The problem ended up being with Itunes not working right. The solution I found was to download the program winamp and download the plugin for apple ipod. Then you can sync and add software thru winamp. After syncing one time it even worked with itunes but I like winamp better, so I synch all music using winamp.
I found out the hard way that the USB charge can actually hurt the life of your battery. It'll get to the point where the power coming in from the USB cord isn't enough juice to power the iPod, but the iPod thinks it should be; problems ensue.
Your battery is probably in a hurting shape now; it'll probably need to be replaced pretty soon. If that happens, ask the people you go through for a high-voltage charger, they usually cost like $20 and push 9.5v instead of 5v into your iPod. It protects the life of the battery.
If you don't know who to get your battery replaced by, I recommend Vaxtex. They did mine, and you can't even tell it was worked on.
I had the same problem and it was my cord. Try borrowing a friends cord, and see if that works.
SOURCE: ipod not recognized by computer or itunes
· Apple logo blinks on and off
· http://www.sharp-tools.net/archives/000240.html
i had this problem with my shuffle and had it with my 7G 3rd generation nano. It does appear to be a usb problem, as suggested. i fixed it both time by go to the Device Manager (right click on my computer - properties - hardware - device manager). If your ipod is connected, you will see the apple ipod DRIVER even when you don't see the ipod in my computer or in itunes. Right click on the Apple ipod driver and uninstall it. Then your pc will automatically reinstall the driver because your device is still connected. After that reinstall happens, you should your ipod in itunes. I hope it works for some!!! I think it's almost always a usb problem. My error happens whenever I plug in my ipod when other usb devices are connected. To be safe now, I have to remove all other usb devices before plugging in my ipod.
contol panel / administrative tools/services/ press stop on apple mobile devices and then start again this should work.
SOURCE: When I plug my ipod into my computer, it doesn't
Maybe you should try this third ipod manager tool - Daniusoft iPod transfer:
Key-features:
1. Sync videos/songs from computer to iPod without iTunes ;
2. Backup videos/songs off iPod to computer smoothly ;
3. Transfer iPod video/music to iTunes .
I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well.
same problem
the ipod say i need the cd so it can work
Same problem, except the computer does not recognize the IPod and the Ipod displays nothing as if the battery is completley dead and unable to be seen by the computer. I have tried to reset with no results. I bought a new cable nothing, please help.
my ipod can not recognized by any computers
