Sir ,when i go to print some of the text jump to next page , i tried to set margins page setup
plz provide me the soulation
margins are set wrong, or there are special
formatting marks and/or characters at the end
of your documents.
START --> Printers & Faxes -> Chose printer -->
right-click --> properties --> ....
This sets the default settings, that are in effect every time
an application starts up.
Also note, that if printer settings are not listed within
your START menu, you can find them in the Windows
control panel. You can change what shows in the
START menu and what doesn't by right-clicking the
task bar.
the file menu:
File --> Print --> Settings ...
File --> Printer settings ...
File --> Page setup .... and also margins. etc...
This sets the actual settings for this application or the
current document. These settings over-ride the global
default setting in item (2)
reflect the way you use the printer the most often.
The settings in item (3) reflect the actual document you
are trying to print now.
reflect the paper in the machine, do not confuse
metric sizes: A1, A2, A3, A4, A5 ....
with English sizes: Letter, Legal,..... etc
These do not line up exactly.
are no extra characters at the end of your document:
Paragraph marks, Page Brakes, Form Feeds, etc.
Also check the paragraph settings (in Word for Windows,
for example, to make sure that is not the cause of the
problem.
In word for Windows, for example, you can also go
into tools, options and change the way your document
is displayed, such that all formatting marks become
visible (or click on the paragraph tool)
of print PREVIEW facility, so that you can see what
you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
By control panel set up you have to set the paper size by 8 ich to 12 inch as per the paper size you required. If once you set this paper size . there is no use by setting the paper size in printer properties or printing preferences.
not the same but similar. have been printing 3x5 continuous pin feed cards for years on this LQ-590 with win95 up to 200 cards at a time. On its own it has started to treat printing as if 8x11 skipping 2 + cards before starting next card. doc page setup shows 3x5 and preview is correct. Also, have inexplicable paper out error in middle of print job when card sheet is obviously running fine from rear tractor feed, sheets not disconnected. Have to power off/on. Have reloaded print drivers. Any suggestions. Epson support gave me boilerplate response on realigning top of page! thanx, kevink
