SOURCE: toshiba a200 laptop Have black screen even tho
You could have a defective screen - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
SOURCE: The phone does not switch on.. when I press the
your phone got deads its happens many times when firmware is not properly updated,try to update your phone firmware but be care or send it to nokia centre
Testimonial: "Thanks Khan, i'll try this"
hi there!
try changing batteries. or try turning it on while charging, if theres no problem when its directly plugged in with the charger, the battery may be dead (especially if its more than a year old and is frenquently used for calls and internet). if its having the error while still plugged in directly with the charger, a local technician is the best here.
