Error code e 70 the control board is not seeing the proper water supply amount in this case check the pressure switch as well as the water valve assure that you are getting hot and cold out f the water valve one from each side if the valve is ok then you would move on to checking the pressure switch how much water is fillinig on the inside of the machine when this error happens? if you have any further questions message me back Thanks again Rick
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
