Kohler Toilet Seat - Elongated Front Quiet Close Quick Release - Cachet by Logo
A
Anonymous Posted on Jan 23, 2011
Toilet seat cracked need replacement and aprrox. cost
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Jan 26, 2011
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801103
Points
33142
Hello. A new seat is available at any hardware store. Elongated seats cost anywhere from 20-40. If you need to have it installed it will be significantly more. House calls are generally at least $50.00. Be sure to get a price up front as it only takes 5 minutes to replace a toilet seat.
If you want to do it yourself, unscrew the old one and screw on the new. That's it. Joe
Thanks for choosing Fixya!
2answers
How do I fix a broken toilet seat?
Toilet seats are often found very durable in designs and most of them are made of wooden or particle board to solid wood. Also padded seats are just a padded induced on wooden seat by any adhesive solution. So, its normal to find crack or patch on a toilet seat after long use or by any accident, which also can be repaired by you without any specialized knowledge. You will not need any advanced tool but Basic DIY tools .
Let see the step by step method of fixing a broken or cracked toilet seat:
Step 1: At first remove that cracked toilet seat from the toilet fixture by unscrewing the seat screws using a flat screwdriver.
Step 2: Spread the crack slightly and push wood glue or wooden adhesive solution inside of it. Make sure the glue coated entire inner surface of the crack.
Step 3 : Squeeze the seat together you can use bar clamp. Wipe out any excess glue on the outer surface of the crack
Step 5 : dry overnight or minimum 6 hours and re-install it.
Note: if you find it's cracked or split heavily , or if it is pinching your back. Or if it seems nasty to look at then think about it .Toilet seats are pretty reasonable, so price shouldn't be an issue. If you don't want to look at the nasty underside, get rid of it and replace with a better one.
This toilet guide will provide you all kinds of essential information about toilet and bathroom fixtures,product reviews , expert's recommendations .
Take what you need and Do it Yourself.
Apr 05, 2018 • Home
2answers
The seat is cracked and doesn't heat anymore, is there anything I can try before buying a new one?
if the seat is cracked then the element is probably broken at the crack site
check for circuit continuity of the element or buy a new seat
can't be too hygienic or comfortable sitting on a cracked seat
Wand will not launch when seat is activated
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism . Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 • Home
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
Nov 25, 2013 • Delta Home
2answers
Where can i get seaat for my ssww toilets they crack all the time
Go online and look for some bemis toilet seats, they are great seats.
3helpful
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
4helpful
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 • Home
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
