Televison & Video Logo
Posted on Jul 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture is jittery and voice is garbled with noise in background
Hi! After I have recorded a program and I want to playback the program the tape runs with a jittery picture and the voice cannot be understood. There is also a background noise. Please help me solve this problem. Thank you. Joan I've had my VCR/DVD player for a few months. It has worked beautifully until a few days ago when the constant vertical jumping during video playback began. I have twice tried a video head cleaning cassette and tried the +/- CH. button many, many times all to no avail. It's a JVC HR-XVC17 which I ordered with my Air Miles. I don't want to have to pack it up and mail it for warranty work. I can't afford a repair shop. Any help would be truly appreciated!
Anonymous
Level 3:
Genius:
  • Master 1,139 Answers
  • Posted on Jul 17, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1139
Questions
Helped
413517
Points
2179
Hello sneakymouse
It looks like you may have a servo or servo sync problem in either your recorder or your player. These are signs of such a problem. The circuitry that governs these function might be beginning to malfunction. Technically there is nothing that you can do in the way of repairing this unit you would have to have specialized equipment to trace down the source of the sync problem which is effecting your system. If you can not afford a repair shop right now I would suggest that you use your warranty and get it fixed. More than likely it is a problem with the servo IC or the sync oscillator circuitry.
I hope this helps,
Thank you,
Shuttle83
1helpful
I have the same jittery picture on playback on a Sony DCR-TRV460. I see you've stated that the drum could be misaligned/damaged. I've used the cleaning head with no success. I need to keep this device...
Yes sometimes when realigning the drum will not work. if the tapes were recorded with the drum out of alignment all tapes would have been recorded out of alignment. Delt with that situation where my player wouldnt play a customers tapes because his drum was out of alignment from factory. I had to use his camera to play all the tapes that were recorded on his camera.
Mar 23, 2011 • Cameras
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Jittery video and sound, and now no playback
You may have damaged the heads if your cleaner tape was old and dryed out and had grit on it, buy a new camera head cleaning tape for a start, never rewind it as lots of folk do, if you do that all you do is put the old dirt back on the head.
How can I clean up a recording that is full of noise & static?
I Don't know of any Olympus proprietory program to remove noise but if you can export it to a .wav format, it can then be edited and cleaned up digitally buy any semi pro sound editing software.such as sony's Sound Forge or cubase? cakewalk. software used for edit old records for conversion to cd may also help here. From there you can then save to cd for playback. If sound editing is beyond you, contact a recording studio or media house that produces commercials, they may be able to help.
Hope this is helpful
Poor playback
Because the cable signal is OK, this eliminates the tuner as your problem and leaves the power supply which is a common problem. It is a switch mode type which often have trouble maintaining control of its output voltages and produce trouble downstream in the video circuitry. Either the power supply is failing which can be wholesale replaced for about a $150, or something somewhere else is failing and loading down the supply causing it to overwork. Usually in this case, you can hear a whine noise if you listen close.
Poor EP playback
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
regards
Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
A lot of background noise when playing back.
The pic looks like a TRC5880? If thats the case they are naturally quite noisey. The motors vibrate too much in my opinion. Theres not much you can do with it unfortunately. Suggest a new recorder or get that one repaired.
2helpful
2answers
I had the same problem recently with a Panasonic PV - V4521 which has worked for years for me. I tried everything including cleaning the heads with Q-Tips and pure alcohol. Nothing improved. I tried tape head cleaners. Nothing. So finally one day, as I was unscrewing the cables, this VCR fell down onto the bottom of my foot and drew blood. Now remember, I had been trying to fix this thing for at least 10 days.
So, I dragged it up and pounded the top of the VCR until the top caved in. Then, I opened my front door and tossed it so hard against the floor of my patio that pieces went flying everywhere. I gathered up the pieces and the twisted VCR, put it in a box, and tosses it real hard into the dumpster. It's fixed. I have no more problem with it.
2answers
Panasonic PV-DV702 Garbled playback - any solutions??
Try a different tape. The tape itself may be bad.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
