I received a rival vacuum sealer for christmas. I tried to use it today to package deer steaks and could not get them sealed. It drew the blood up to the top with the air and could not seal. I cut the top of the bag off and tried to reseal it several times and each time it continued to do the same thing. Are these not made to seal something with moisture in it, or what is the problem. It sounded like a great appliance but I ended up putting bag and all into a zip lock before I put it in the freezer. This method is not only time consuming but also expensi ve. Can you give me any help? Thanks Mary
There is air leaking in somewhere. Make sure there are no wrinkles in the bag at the sealer location. Also, make sure the seal on the bottom of the bag is complete or the machine will simply suck air from the bottom and out the top. Make sure there are no food particles stuck in or to the sealer mechanism.
I don't have a Rival but have a Foodsaver vacuum sealer. If I have trouble getting the air to vacuum out, I remove the black foam seal from the machine, run it under water for a minute, shake off the excess, and reseat the seal. For some reason, the water helps create a seal. It also helps remove food that may have leaked onto the foam seal.
If the wire that heats and melts the bag is damaged, it may not be sealing the bag completely.
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com, Inc.
Rating: 3.6 - 233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
It may be that the gaskets are faulty. Vacuum will keep running trying to draw air out before sealing. If that is your problem I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012). this part is not listed in the seal-a-meal website, only available by calling.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
