SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
SOURCE: I have functional problems SC547-00 of Aficio
fix the problem with the fuser and reset in service mode
SOURCE: error code sc 306 aficio 1022
code 306 is not exist.
Try pressing. and # for more than 10 seconds.
He is not
recommendable if you is not a technicians but Lost by lost this restores software. So that later it is necessary to make
adjustments since the copier returns to values of factory.
SOURCE: after sc326-00 my copieur ricoh aficio 350 put on
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
