The first thing that I would check is to see if there is a GFI outlet inline with the other outlets that are not working,, if there is one then check to see if you can reset it using the little reset button -- if by using the reset button does not fix this problem then there is the chance that the GFI outlet is bad and needs to be replaced. the next thing that comes to mind is that you said the breakers in the box are good, but I have seen sometimes where you need to flip the breaker totally off and then back on and this could reset the breaker. if you are still having troubles then the problem could be that one of the outlets in line has gone bad and needs to be replaced or the breaker in the box could also be bad ( use a meter to check that you have power on the output side of the breaker and trace from there from outlet to outlet until you find the bad one ) ---- could also be just a bad wire and while testing with your meter you should find it as you test the wires to the outlets.
c...
