Expert
- Posted on Jan 22, 2011
Re: Fuses are good replaced cam,crank sensers auto shut...
If the auto shut down is just buzzing it is the relay engaging and disengaging really fast you have either weak voltage or weak control signal coming from the pcm possibly a bad wire. also try to switch relay out with one that is similar in the fuse box to see if it is a bad relay.
