I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Krups brew head seal at a resaonable price, contact me at [email protected] and I'll make arrangements. I purchase the groups seals directly from Krups and they will arrive sealed in the manufacturer's original plastic packaging. I accept Paypal to make the transaction safe and secure for us both.
SOURCE: When I make coffee, there
there are several places where this machine can leak. Check all the connecting hoses from the boiler , they are just clicked in by holder pins.
Even the seal in the boiler itself can be worn.
Follow this link for diagram and parts ( unfortunately in spanish sorry for that)
SAECO VIENNA SA
Oh by the way the seal on the spout which goes into your brew group can be damaged too. Check that first
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
SOURCE: Gagggia Platinum Swing no longer makes coffee
It seems that the coffee solenoid valve is the problem. It does not open since the noise indicated that is damaged, so you will need a new solenoid valve. If you manage to reassembled it then you can try to remove the internal body with spring inside solenoid with this the valve will be always open and you will have continiues water from the group shower. If this happens than you are 100 % that the valve is the problem.
Good Luck
Remember to vote for this answer.
Testimonial: "Thanks for that. I thought i may be a trip to the repairers as that is a job beyond me. How long can i go without coffee?"
SOURCE: My machine has worked beautifully for several
I have had the same issue, this is just the group head gasket that needs to be replaced. I got all the parts and I am going to try and replace it myself
