Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the service mode for a Lanier 5627? - Lanier Office Equipment & Supplies
Anonymous
Level 2:
  • Expert 263 Answers
  • Posted on Jan 22, 2011
Anonymous
Expert
Level 2:
Answers
263
Questions
0
Helped
132639
Points
586
Why you continue to ask the same things? Why do you continue to put new posts? If you answer when I suggested that perhaps you have your problem solved.
Lanier 5518 with a sc541 code
To clear enter service mode and cycle power,(push in sequence clear modes(yellow) 1 0 7 then hold the stop(red) for 5 seconds) -Carl
1helpful
2answers
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
5helpful
Lanier model 5627 with fault code sc542 upon power up.
LOL I think I already gave you a solution try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
Lanier model 5627,fault code SC542 upon power up
try this:
6. Turn ON
And thats it
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
2helpful
How to enter service mode on a lanier ld225
Press Clear/Modes, then 107, then press AND HOLD Clear/Stop
This will get you into the service mode screen.
Know what you are doing before going into any modes and changing anything.
Good Luck and Thank You for using Fixya
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
1helpful
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
