Maybe you need to calibrate it. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2 2) Hold down the Hint (?) button while turning
the unit on. Continue to hold the Hint button down until the LEAPSTER2
menu appears. Remember that you need to hold the "Hint" button down the
whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options
Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you
do not see this menu after powering on the Leapster2, turn the Leapster2
off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld. 5) Using the stylus pen, touch each of the crosshairs that appear 6) Restart unit Source: http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
