Thank you for your question. I hope this helps solve the problem you are having with your Hot Wheels Color Shifter not changing colors.
I believe your issue may stem from the temperature of the water you are using. You will need two bowls of water - one with ice cold water and the other with hot water. Dipping your car into the ice cold water should change your car into the green color you are looking for. Dipping your car into the hot water will change it back into its original color. Here is a link to a youtube video demontrating this process - http://www.youtube.com/watch?v=2gZf7BKtInU&feature=related.
If this does not help, I would suggest you return it and get a new one. It may be defective.
Good Luck with your color shifter and have fun!
