HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
S3842 uk FREEZES ON BOOT every time have to switch off. on 3rd or 4th attempt works fine. any new software that requires reboot - it does this without a problem. started 2 months ago with original Vista loaded - thought Win 7 upgrade would cure but no! since then done clean (i think?) reinstall of Win 7 from upgrade CD - no Vista disc so then tried to install XP but get blue screen of death. help!
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Jan 22, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1540033
Points
28391
Upgrades are usually troublesome as they leave bits of the old OS in odd places. It is best to do a clean install.
Choose your OS, either Vista or Win7. XP will not work!
Always download the latest drivers for the OS you are using from hp.com or it will keep hanging and be unreliable.
Hope this helps.
Starter draw amps kohler cv16s engine
The starter windings may be shorted, that would explain the draw, if the starter is ok then the engine has really got a problem.
Sep 27, 2016 • Garden
No display problem, vga's out to external, then after 2nd reboot, internal display works, but with errors
If you have already replaced the screen...
Common problem when replacing equipment on laptops is that the "cable" goes into a flat housing that requires you to lift a little white "gate" then insert the cable and put the "gate" back down. Problems usually occur when snapping the "gate" back down. Pull the cable back out and be sure to lift the gate insert the cable and then put the "gate" back down. Once done give it a light tug and it should hold very firm and not move at all
My powerbook g4 won't reboot. It freezes at the grey screen with the apple and won't let me log on .
Power the machine down. Press the power button, then immediately press and continue to hold the shift key. This will perform a "safe boot," skipping any of the boot-time software you may have added to your machine. If it still fails to boot, more involved diagnostics are required.
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
1helpful
Receiver freezes every few hours
It sounds like something else may be causing an issue. Since so many replacements have been made, but the problem persists I would recommend getting a technician out to look at the problem to make sure everything else is fine.
Tommy Faust
DISH Network Customer Service
Hi , my abit pro 9 bios doesnt safe ,,want to install windows on a new empty drive but therefor i need to change boot device , i choose cd rom , then F10 to safe , but it freezes there , doesnt safe ,,,...
for your first boot cd/dvd rom, 2nd boot hdd is it serial ide or sata, then you can disable the 3rd boot device, if it freezes and does not save reboot your pc in some motherboard there is key to press for you choose which device to boot first if you find the key sometimes its f12 or f10 when press this it will promt which device to boot first then choose which of those devices you want to boot first
Toshiba A105-S101 freezes at start up!
I would first attempt to reinstall the software from the install cd. Your Toshiba support page is recomending a new BIOS upgrade. See below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209144&rpn=PSAA2U&modelFilter=A105-S101&selCategory=3&selFamily=1073768663&selModel=1209144|PSAA2U
System froze while installing software update
well you have no choice but to turn it off...hopefullly when you reboot the machine it will attempt to reinstall the firmware..usually that is what the unit does. if it freezes again at 100percent it very well could be the 3rd partion sector of your SATA drive....ive seen this before.
Wifi switch problem
At first guess, I'd say you have a driver problem. Reboot the machine in safe mode, leaving the switch in the "ON" position. (F8 at startup for safe mode).
Log into the machine, and go to Device Manager. Uninstall/remove the wifi adapter.
Reboot.
Upon reboot, the system will attempt to reinstall the adapter, but you should not have a blue screen. If you have the original drivers, point Windows to them. You don't want Windows to use the "existing" drivers, because that's where the problem occurred.
Once the good drivers are installed, you should be back in business :)
Hope this helps - remember to rate!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
