Run Norton Anti Virus to remove viruses.
1. Disabled “System Restore” in cleaning process.
2. Kill wscript.exe process from your computer background programs.
3. In cleaning process you have to rename file wscript.exe to any name ex:blabla (temporary only in cleaning process) and don’t forget to rename it back again to wscript.exe once your computer clean.
4. Deleted file “database.mdb” from “My Documents” folder.
5. Disabled any startup process which has link with “database.mdb” you can use msconfig or hijackthis.
6. Delete file autorun.inf, microsoft.inf and thumb.db use command prompt and type “del Microsoft.inf /s” (should in root drive to deleted in all in drive) for autorun.inf and thumb.db since this file set with attrib RSHA type “del autorun.inf /s /ah /f” (should in root drive to deleted in all in drive, change autorun.inf with thumb.db to deleted all thumb.db)
7. deleted all .lnk files with size 1kb
7. deleted all .lnk files with size 1kb, you can use advanced search function.
Fixing a Virus infected PC is not an easy task.
However if you fixed it, then again there will have lot of issues due to the changes done by the virus to windows system.
The ideal solution is reinstall the system again and install a virus guard.
For removable devices like Flash Drives, Memory Cards you can use Shortcut Virus Remover.
100% free simple application.
Download Link - Shortcut Virus Remover
Download from www.biomosquito.hpage.com 1kb virus removal
and scan system file and pendrive .scan with avast free antivirus.
working almost
good luck
what virus type is it and what does it shortcut to
