To save caller ID with a name in Panasonic KX-AT7730, you need to follow these steps:
Press the "Program" button on the phone.
Dial "9" to enter the "Caller ID" setting.
Dial "1" to enter the "Caller ID Memory" setting.
Dial the memory location number (0-99) where you want to save the caller ID and name.
Enter the caller's phone number using the keypad.
Press the "#" button to move to the next field.
Enter the caller's name using the keypad (use the alphanumeric keys to enter letters).
Press the "#" button again to save the entry.
Repeat steps 4-8 for each caller ID you want to save.
Note: Caller ID service must be enabled on your phone line for this feature to work. Also, make sure you have enough memory locations available in your phone's memory to save new caller IDs.
It may be enabled, but normally you have to pay for it.
Page 54 of the manual. It is automatic.
Using Caller ID service
Important: This unit is Caller ID compatible. To use Caller ID features, you must subscribe to a Caller ID service. Contact your service provider/telephone company for details.
I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
unplug the one that gets caller ID and one more. Do you get caller ID on the remaining phone? Caller ID is sent between the first and second ring, as well as the second and third ring. It may be that the other phones require that 2nd Caller ID signal and you've answered it elsewhere.
I am assuming that the other phones have a display and are Caller ID capable phones. Can you post the model numbers of the phones that don't get Caller ID? We can then try to locate a user guide for them.
Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
Is the battery old? - Replace the battery.
Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
Do you have CallerID service with your telephone company - In order to receive CallerID records, you must subscribe to the standard name and number CallerID service available through your local telephone company. If the CallerID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
CallerID shows up after second ring - Be sure to wait until the second ring before answering. CallerID signals comes through after the first ring, if caller pick ups phone too soon CallerID signal will not be transmitted to the handset.
Confirm that callerID is still working on that particular line by checking another phone on the same line - If CallerID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Please download this manual, and study e.g on page 21 About caller ID
If you subscribe to caller ID service from your local telephone company, this feature displays the
name and telephone number of the caller before answering a call (even when you are on another
call). The caller ID features of this product will work only if you subscribe to caller ID service and
both you and the caller are in areas offering caller ID service, and if both telephone companies use
compatible equipment.
Contact your local telephone company if:
• you have both caller ID and call waiting, but as separate services (you may need combined service),
• you have only caller ID service, or only call waiting service,
• you do not subscribe to caller ID or call waiting services but wish to try them.
There may be fees for these services, and they may not be available in all areas.
This product can be used without subscribing to either caller ID or combined caller ID with call waiting
service, although the caller ID features of this product will not function.
http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888.In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Caller ID information is passed between the first and second rings.
Try connecting a regular corded telephone or a standalone Caller ID box. Does Caller ID information show up?
If you have multiple telephones (I don't mean a single cordless telephone base with multiple handsets) and none of them are showing Caller ID after 3 rings it would appear that the telephone company does not have Caller ID turned on for your telephone line.
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
