Sony PlayStation Portable (PSP) Console Logo
Posted on Jan 22, 2011
Hoe to download games and play in psp - Sony PlayStation Portable (PSP) Console
A
Anonymous
Click on this link below and follow these four steps to download games to your PSP:
http://ezinearticles.com/?Download-Games-To-PSP-Four-Easy-Steps&id=606543
Everytime i go to a psp store,the store owner always say that my psp needs to be modified b4 they can download games into my psp. Does my psp really needs to be modified to play downloaded games?
Yes and No.
The only legal download games are in the Playstation Store.
If you are downloaded illegal versions of the PSP games, you need a modified PSP to play them.
If you are attempting to download ROMs to play on emulators, you also need a modified PSP to run the emulator.
Cant play games downloaded for psp
make sure that you put the downloaded games in the GAME folder (capital letters are important) which itself is inside the PSP folder (capitals also important) so the folder you would put them in would look like F:\PSP\GAME\
All game files should end with PSP.
To play the games, from the PSP menu go to GAME then press X and scroll to select your game then press X again to confirm.
If your PSP firmware is above 1.5, it might be that you are trying to play protected games and it is why they cannot play.
Make sure you do not violate any intellectual property.
Regards,
1helpful
2answers
Hoe to download psp games for free?
This tutorial will explain how you can download PSP games for free and play them off your memory stick.
If you need any help with putting games on your PSP or any other related PSP help, contact us on PSPWarez.ORG!
Go to http://pspwarez.org
1.) Register (without registering you will not be able to enter the games section!).
2.) Go down to the "Games" section or use the "Search" button.
3.) Find a game you would like to download and save it to your PC as shown in the video.
4.) After download put the game on your PSP and lauch it .
wWw.PSPWarez.ORG - All What Your PSP Needs
PSPWarez is a PSP website where you can download:
• PSP games
• Movies
• Homebrews
• PSP Tutorials +Some PS3
• PC games
• PC Software
AND A LOT MORE!
And the best thing is that...
IT'S ALL FREE!
1.) Go to wWw.PSPWarez.ORG
2.) Register.
3.) Download & Post.
You can also watch the video on youtube through this link: http://www.youtube.com/watch?v=M2190CV4aVU
If you find it hard to read what is in the video, just pause it!
2helpful
2answers
How do i download free psp go games
Like many others who had purchased original PSP games from the retail outlets, you will realize that as the games is completed, buying new games seem to be getting expensive and unaffordable. What else can I do if I want to continue to play new or old fashioned games on my PSP console? I start search and looking for website that offers free PSP download games.
Once I had downloaded the PSP games onto my console, how to play PSP download games was my next question. I'm not sure exactly how PSP works when I download new PSP games onto the unit, but I sure have found some answers while I was looking for it. Since I'm facing and struggling with this problem on how to play PSP download games on my unit, lots of other people must be also getting the same problem.
Hope that I get this right for everyone to play PSP download games because I used the same method here to play on my console. Before we get started, I'm using a PSP unit with firmware of 1.5 and having a Sony PSP compatible memory stick pro duo.
Since you are going to download the PSP games, you must download the games for the correct version of firmware, if not it will not work. Newer version of the firmware is available to anyone from the PSP official website. Most homebrew PSP games works with firmware 1.5 and below because the newer firmware upgrade is trying to block people from using homebrew games. Make sure the games you are downloading ends with PSP because only PSP files are compatible with Sony PSP unit.
instruction
  • Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  • To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  • Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  • Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
  • 0helpful
    How can i play download games on my psp 3000 version 6.31
    your psp version 6.31 can download psp games, u need to downgrade it from 6.31 to 5.00 to be able to download, upload and play games. try this link to downgrade psp http://www.youtube.com/watch?v=4COQtaUPNHU
    I want free downloads of sony psp3000 memory stick games
    For you to download and play games on your psp, please follow the steps listed herein;
    1. Since you can download directly to your PSP memory stick, you'll have to download to your computer and further transfer to your PSP memory stick.
    2. You'll have to modify the PSP from the official version to a custom version. You can find out how to do this by typing in this search "How to hack PSP to custom firmware"
    You can now do the following to transfer and play games;
    a. Get a good memory stick. I recommend that you get a Memory Stick Duo in at least a 1 GB size, though a 2 GB is even better.
    b. Find and download the PSP games you want. If you don't know where to find the games try a download service. A good one will let you have unlimited downloads for a small one-time fee. You can see the link below for more information.
    c. Unzip the game files and save them somewhere that you can find them easily, like your desktop.
    d. Plug your PSP USB cable into your PSP and your computer.
    e. For PSP games- go the the root directory on your PSP then make a folder called ISO. (If you downloaded PSOne games, go to the root directory on your PSP and find the folder called PSP/GAME.)
    f. Copy the PSP game files into the ISO folder. (Copy PSOne game files into the PSP/GAME folder.)
    Once this is done you can now play games on your PSP.
    Regards
    2helpful
    2answers
    How to download games on psp 3004
    There are different kinds of games for the PSP. There are Flash games, ISO/CSO games, PBP Games, etc. Depending on your firmware type, (Custom or Official) there are special kinds you can play:
    Flash games are small, quick games you can play on your PSP Browser. They don't require special firmware to run. However, the flash games tend to run slow because of the lack of memory. Download them to your PSP/COMMON Folder and type in the location of the content in the address bar.
    Ex: file:/psp/common/name.swf
    For PBP Games, you can download them from the PSN and save them to your PSP/GAME Folder. These games are mostly demos. The PBP Files should have its own folder under PSP/GAME. To play them, go to your game section of your XMB and if you did it correctly, the game should be there.
    Now, for ISO/CSO files. These are Disc image files that can be played on your PSP. They're usually for backup purposes. You save them in your ISO Folder (You might have to make this folder). To play them, just play as you would with a PBP Game.
    3helpful
    2answers
    How to play download game for psp 3006
    you cannot play downloaded games on the new psp 3000.
    How can i play download game for my new psp
    How can I download game in my PSP2001 version 3.95 ?
    u have to first go to the PlayStation store on your psp then u download the game u want and just wait until it's finished loading then go to saved game utility under games and try it.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
