Need to eliminate possible causes. Easiest way is to try your monitor on another computer, if it works then that is ruled out. Try your computer with another monitor. Try another cable between computer and monitor (both yours and borrowed one). The problem can be the monitor socket and wiring, the computer socket, wiring or program and finally the connecting cable.
Make sure you are connecting the monitor signal lead to the correct signal output on the rear of the machine. Some desktops have extra video out connectors when they have a graphics card fitted. If yours has a graphics card the display connector will be away from the back USB ,audio and keyboard ports and near to some silver pop out panels near the bottom of the tower.
If the computer hangs for a while and reoots and then works the monitor, it tells me that the signal to the monitor went dead until rebooting. It is as if you unplugged the monitor from the vga or dvi card, or it was getting an incorrect signal from the vga or dvi card. It may not be the monitor, so much as it is the computer doing this to the good monitor.
One can test to see if the monitor is bad by using it on another computer tower or desktop to see if it does it there. Good luck on this diagnosis.
I was just dealing with this last night. My pc would come on, but I kept getting a "No Signal" message on my monitor. I first plugged the machine into a known working monitor. It worked fine so that eliminated the video card issue. Then I plugged the monitor into a different computer...it too worked. So I knew that the monitor was good. I then switched the cord from the faulty monitor and still didn't get a signal. I proceeded investigating the issue. I found that if you boot the machine in safe mode, it actually caught a signal. So...I figured it must be something to do with the resolution. My solution: Boot the machine in safe mode, change the resolution in the control panel and reboot the machine. If it doesnt catch the signal booting in safe mode, I suspect it is a faulty video card. You are likely to find what you are looking for online at zipzoomfly.com or newegg.com
You'll need to check the cable connections and the computer that it is attached to. The monitor may be going into standby mode because the computer went into Suspended/Hibernate mode. Try restarting the computer. If you're unable to do this, try a hard power off and then try to turn it back on.
