The volume button on my Sansa Clip seems to be stuck. The volume is all the way down and won't turn up, so I cant hear the music. Is there anything I can do?
mine is the same way i dont know what to do and i really dont wanna buy another one cause i got like almost 200 songs on there someone help me !! :(mine is the same way i dont know what to do and i really dont wanna buy another one cause i got like almost 200 songs on there someone help me !! :(
Well, I contacted Sansa and they sent me a new one! I guess that is the only way to fix the volume problem!!Well, I contacted Sansa and they sent me a new one! I guess that is the only way to fix the volume problem!!
the volume on my sansa is stuck all the way to low i have try everything possible to listen to my music but it seems to be impossiblethe volume on my sansa is stuck all the way to low i have try everything possible to listen to my music but it seems to be impossible
AnonymousMar 23, 2014
The volume button on the side is broken, and is stuck on the lowest volume setting. There's no clicking possible for higher volumes. Is there a way to manually fix this?The volume button on the side is broken, and is stuck on the lowest volume setting. There's no clicking possible for higher volumes. Is there a way to manually fix this?
You can't post conmments that contain an email address.
1. Press Menu button to return to the Main Menu.
2. Move down to Settings and select it.
3. Select Volume.
4. Highlight the desired volume settings then press Select button.
This thread explains the problem and may help you if you are good with DIY stuff. http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=18157
My problem seems to be a damaged volume button. Once I tour the volume down (the down button is fine) I could not increase back de volume. This is a palliative sollution. You need to reset you Sansa clip to get the volume set to the "middle" of the range. To steps are: 1) clique in the "home" button. 2) navigate to "settings" 3) select the "Reset All" option and confirm it.
Make sure the lock switch isn't engaged.
Double-click My Computer, and see if there is a Sansa icon (some computers will only show it as a removable drive or an MTP device).
If the computer is not recognizing the player:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
i think you cotinously keep on increasing and loweing the volume in you sandick mp3 player take it to the repair electronic shop the rubber below your volume key get dispalced sometime or get stuck due to which it doesnt work. dont worry i hope it can be repaired
This is the method that will force Windows to recognize the Sansa:
Try this: disconnect the player from the computer, turn it off,hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
