LG GSA 4163B DVD±RW Dual Layer Burner Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dvd rw not showing up in My Computer. It plays dvd and cd as normal but can't burn.
Brian Sullivan
Level 3:
  • LG Master 27,725 Answers
  • Posted on Jan 22, 2011
Brian Sullivan
LG Master
Level 3:
Answers
27725
Questions
Helped
5664408
Points
79191
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Recording/burning to disc
I searched your system and it shows a CD/DVD/RW.
So you can burn CD, DVD+R RW and DVD-R RW
So the most common DVD media would be the DVD+ media.
CD media would be all CD media. (info) RW: Re-Writable
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
3helpful
2answers
Can I burn dvd movies with dvd r disk on my TSST corp CDW/DVD TS-H492A
You can only burn DVD's with a dvd-rw.
A CD-RW DVD will only play a dvd and write CD's
How do I burn a dvd so that I can play it on other dvds than the one that I burned it on?
This doesn't make sense.
If you want to burn a DVD so it plays on all "DVD Players" you can buy a program called Nero for Windows or Toast for Mac.  You will also need a DVD RW disk reader since you can not burn a disk on a normal DVD drive or CD drive on you computer.
Regards
1helpful
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
1helpful
2answers
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
1helpful
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
1helpful
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
DVD disk
check to see what format your computer burns on.[ex:dvd-r, dvd-rw,dvd-+r,dvd-+rw]different dvd players play certain dvd formats.the format for burning on your computer is probably different from the dvd players that aren't playing the disc.you also must finalize the burned disc.
good luck
wg
Dvd writer wont accept dvd-r
If you have posted the correct model of writer, then it only supports the writing of DVD+R and DVD+RW discs, but CD-R and CD-RW disc writing are supported, and it should play all forms of DVD, so it won't burn DVD-R and RW discs, but if it wont play all types then try a cd/dvd cleaner, but to be honest when writers start playing up the lens is normally faulting and a replacement drive will be required.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
