engine code
HFY
HFZ
KFX
K6C
engine type
TU1JP
TU3JP
TU5JP
special features
without
without
without
type of cylinder head gasket
fibre
fibre
fibre
theoretical thickness (mm)
UNK.
UNK.
UNK.
repair dimensions (mm)
UNK.
UNK.
UNK.
bolt length (mm) (mm) (X)
nominal
max.
maximum cylinder head bow (mm)
Toyota 4A/ 5A-FE Cylinder Head Torque:
(a) Apply a light coat of engine oil on the threads and under the heads of the cylinder head bolts.
(b) Install the plate washer to each cylinder head bolt.
(c) Install and uniformly tighten the ten cylinder head bolts in several passes in the sequence.
Torque: 60 N-m (610 kgf-cm, 44 ft-lbf)
HINT: Cylinder head bolts are in length of 90 mm
(3.54 in.) and 108 mm (4.25 in.). Install the 90 mm
(3.54 in.) bolts (A) in intake manifold side positions.
Install the 108 mm (4.25 in.) bolts (B) in exhaust
