From the Operating Manual: Manual Operation for Non-Programmable Thermostats Press the SYSTEM button to select Heat or Cool and use the [Up] or [Down] buttons to adjust the temperature to your desired setting. After selecting your desired settings you can also press the SYSTEM button to select AUTO to allow the thermostat to automatically change between Heat and Cool. Manual Operation (Bypassing the Program) Programmable Thermostats Press the [Up] or [Down] buttons and adjust the temperature wherever you like. Then press HOLD. This will override the program. The HOLD feature bypasses the program and allows you to adjust the temperature manually, as needed. Whatever temperature you set in HOLD will be maintained 24 hours a day, until you manually change the temperature or press RUN to cancel HOLD and resume the programmed schedule. ____________________________________________________ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
