SOURCE: Blackberry Curve 8330 call problems
well the phone is a really good phone, I would look at your provider.
on a regular day how long does your battery last? is it lasting less and less.
One of the nice things about the blackberry is you have the ability to reinstall the software if you need to.
so try what you can and if all else fails, do a reinstall of the software.
or download the desktop manager from blackberry.com and update your software.
maybe that will help.
good luck
SOURCE: Blackberry storm has random resets
Remove suspicious apps one by one. If the problem remains after removing all apps restore the firmware to factory using the desktop manager. If the problem still remains there may be a hardware issue. If you're out of warranty there are Blackberry Repair Guides if you want to attempt a DIY repair, logic boards are on ebay.
SOURCE: No keys on my curve work except the trackball.
Install Blackberry desktop Manager ...Take Backup.. Reinstall the Software ....if not happening contact service center as there might be any hardware problem.
SOURCE: Blackberry Curve 8520 Signal problems
I don't think this is a phone problem.Bad signals is caused by network provider or probably you are in an area where signals is poor. But i don't think its a phone problem. Try leaving your area and go to another area and see if the problem still persists. Then you could see a Blackberry technician.
Best regards
SOURCE: Hi my name is dean
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
