Emerson EWC20D3 20 in. TV/DVD Combo Logo
A
Anonymous Posted on Jan 21, 2011
What replacement remote works best with the tv/dvd combo? I can,t find one that will work both the tv or dvd.
Chi Chu
Level 3:
  • Emerson Master 8,457 Answers
  • Posted on Jan 21, 2011
Chi Chu
Emerson Master
Level 3:
Answers
8457
Questions
0
Helped
2820434
Points
26282
Try website Remotes.com to buy an original very close to the original remote.
Can I Bluetooth this model Broksonic CCVG-2070.
This is a low tech antique television. You can't connect a phone to it!
http://www.broksonic.com/mainCTgv-2727.htm
No manual
https://www.google.com/search?q=broksonic+ccvg-2070+manual
Here is a replacement remote
BROKSONIC CCVG2070 Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem...
Replacement Remote control for the BROKSONIC CCVG2070. ... BROKSONIC CCVG2070 Replacement Remote. $3490 $34.90. BROKSONIC CCVG2070 Replacement Remote. Default ...
US$34.90
Broksonic
Amazon.com https://www.amazon.com > Broksonic > k=Broksonic
Replacement Remote Control for BROKSONIC SC20145, 076D0FH010. Infrared · 2.92.9 out of 5 stars (8) · $34.95$34.95. $4.89 delivery Dec 21 - 26. Only 8 left in ...
Broksonic Sansui 076R0HE02B TV/DVD Combo Remote ...
Best Deal Remotes https://www.bestdealremotes.com > products > brokso...
This Original OEM Broksonic Sansui 076R0HE02B TV/DVD Combo Remote Control works with the following models: CCVG1440, CCVG1530, CCVG2070, CFTD2052, LCDVD200A, ...
tip
Polaroid TV DVD Combo Remote Codes Can't find a code to program your universal...
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 • Televison & Video
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
Codes for uneversal hd toshiba dvd combo tv
A universal is not likely to work for a combo unit---best bet is to Google the model number of the set and try to get an Original remote for it.
I have a apex combo tv/dvd player i lose the remote. I bought a universal remaote. I got it to work the tv but cant get it to operate the dvd
Hello
With a universal remote control, we can't get allthe functions do work as its orginal one. You have to check other codes for Apex, described in its user manual. Check other codes, and see which one will do best to get most functions with the TV. OK.
1helpful
Need code for SV2000 tv/dvd combo & Comcast remote,
Any remote supporting Sylvania TV/DVD combos will work for these tvs. I had a Zenith universal remote working with this TV.
1helpful
2answers
My R C A Remote will not turn my R CA T V DVD off
If you have an RCA TV/DVD combo model #20F510TD....... I may be able to help....somewhat.
I was able to program a (Walmart) RCA 3 device universal remote control ( $9.96)
but only for the TV. I could not get the remote to program for the DVD.
The code for the TV function is #1122. Good Luck!!!!!
RCA controller not working
I have a similar problem with my universal remote and DVD player/recorder. there are some remotes that will not work with a different brand of unit, that is the best I can tell you.
9helpful
3answers
Remote control code for a daenyx tv
My Daenyx DN-191 D TV remote stopped worked after a while. I didnt get one universal remote that works with this piece of junk. I called their customer service at 1-877-329-8351. They said the remote will be $30 + $7 (shipping) + tax. Your best bet will be to buy a replacement remote or better toss this junk off the window.
2answers
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
