Air-O-Swiss AOS 7135 Humidifier Logo
Posted on Nov 14, 2017
This humidifier was giving to me it works great its still new but when my sister gave it to she din't had the papers how to clean it so it keeps telling me to clean but i don't know how or where to clean it i love this humidifier it does.not make a noise love it can you please let me how to clean it thank you my name Bernadette
How to change from summer to winter
Can you give a little more info? Usually depending on where you live, people use de-humidifiers in the summer and humidifiers in the winter. If you need a humidifier year around, there should be nothing you need to do uther than filter cleaning and checking the water valve and cleaning the pan of mineral deposits. Depending on your water, you might need to pour a cup of limeaway in your pan and let it run for a couple hours. Then drain it, flush it, and let it keep running.
Moldy smell
Replace humidifier media pad (filter) with a new one, and clean interior of humidifier housing with a solution of warm water and vinegar, also replace or clean furnace filter, Good luck.
Mar 02, 2010 • Humidifiers
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
After one season the model 700 doesn't turn on
clogged solonoid? clean filter and orifice
19helpful
3answers
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
4answers
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
2answers
Water not running through humidifer
Mine had the same problem no water through the solenoid. It turned out to be the little adapter with the needle hole on it, attached to the solenoid on the intake side. It was clogged, cleaned it out and works great now.
2answers
Noisy humidifier
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures. If it seems loose, vibrating parts are causing the noise: 1) Disconnect the power. 2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary. 3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual. 4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
Top Air-O-Swiss Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Air-O-Swiss Humidifier Expert? Answer questions, earn points and help others
