Hi, just try the CDKEYS that may help you. Thanks and enjoy your day!
There are certain games that may be classified as some sort of special edition games. These games which you have listed above can be said to fall into this category.
Majority of these games are made specially and specifically for some systems or console.
The only sure way to be sure if your disc is damaged or not is to try playing it on another console and see if it gives the same error.
If it does give the same error, you can be sure that the disc is really spoiled and the only thing to do is to try to fix it or get a new one.
On the other hand, if it doesn't show this error, you could check to make sure that is possesses the same region code as the region code of the disc that your console is designed to work with.
This is a sure way to know if your disc is bad or isn't just compatible.
Although, it is most likely that the problem is coming from the disc and not your console as other discs work
Let me know how far you went with this problem.
