Ad·www.fireplacepartsworld.com/
Parts for Dyna-glo RMC Lpc80dg. Genuine Fireplace Parts. Shop Now! Fast Shipping. All Brands and Models. Photos of Parts & Models. Live Chat. Types: Motor, Handle, Grate, Bulb, Igniter, And More.
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Harley horns fail. Replace the horn. If this fault has happened at the same time as engine wont crank then problem with wiring. If not then check starter relay (grey one). Also check ignition switch. Are the head lights coming on when turned on? If so the ignition switch is o/k. Connect a voltmeter to horn to check horn circuit. Accessory fuse 15 Amp supplies horn circuit and brake light and turn signal circuits so if these are working fuse o/k. Ignition/start circuit requires system relay and ECM fuse to be o/k. If fuel pump operates when run switch is activated then system relay o/k. Check start relay and circuit to start button.
