Toshiba 27D46 27" TV Logo
Anonymous Posted on Sep 22, 2017
I have a Toshiba 27D46 that will not turn on. Apparently it's been fixed before by replacing a capacitor but that's all the info I have. I haven't the foggiest idea where to begin trying to diagnose this one. The fuse is good, the caps all seem fine, etc. Someone with a little more expertise, please offer some input on how to go about doing diag. Thanks.
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Dec 25, 2006
SOURCE: HDMI Input Failed
I've been seeing alot of this out in the field. The cable is thick and heavy, after awhile the HDMI connectiion inside the set comes apart and breaks from the main board. In my opinion the only difference between Component jacks and HDMI inputs is the thought of reducing the amount of wire mass in the back of the unit. It's more pleasing to the eye. If it's under any kind of warranty, call a servicer. The main PCB will need to be replaced. If it's not under warranty, use component input cables, you'll get the same performance from your set and save a few bucks.
Anonymous
  • Posted on Apr 26, 2008
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Anonymous
  • 1512 Answers
  • Posted on Jul 13, 2008
SOURCE: Toshiba 27D46 27" TV Problem
Hi
It will not be the picture tube. Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
A
Anonymous
  • Posted on Nov 07, 2008
SOURCE: toshiba 27d46
IT probably is the main PCB part number 72783606 costs about $165.00
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on May 16, 2009
SOURCE: Toshiba 27d46 27' TV
Change the vertical IC
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
http://www.manualowl.com/m/Toshiba/27D46/Manual/33233
I have horizontal lines running across a two to three inch section at the top of the set. Is there a way to fix this? Maybe a way to ajust the vertical sink? These lines show always regardless of video...
From your description it sounds like a vertical problem, the IC in the vertical sector may need to be resolded or replaced, there are 2 or 3 capacitors that should be checked that are very near the IC. This is a very common problem with Toshiba sets, and are worth getting repaired.
I have a used toshiba 27d46 using a universal remote and cannot change input to use dvd or wii
I recommend you to buy somo phillips universal remote control to make him change it
6helpful
Sides of picture cut off on Toshiba 27D46
Check for dry capacitors on the tv board
Is converted box necessary for Toshiba 27D46 tv
The Toshiba 27D46 has a digital tuner, so you should be good to go when the switch to digital occurs.
My toshibia model 27d46 tv will not turn on
Toshiba flat-screen digital SDTV, 27", won't turn on. Was difficult to turn on for awhile, but some channels had no sound, others that were in English usually, would suddenly turn into Spanish language. A loud static noise would occasionally come on, and then go. TV just won't even turn on now. Is there any possible repair that would be less expensive then replacing the set? I can't lift the set,as it is much too heavy. I'm a senior, and I'm strong, but not that strong.
2answers
it should cost you from $50 for dry solder joints up to about$120 for a rebuild of the vertical stages.
Toshiba 27D46
Hi
regards
robotek
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
