The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
