Question about NorStar T7316E Corded Phone
I have recorded a main greeting on our nortel phone system but there is not an option to delete the existing one so when you call our main line the recording I made prompts and when it ends the old message starts to play, how do I erase the old message? Nortel model #T7316E Thank you
SOURCE:
SOURCE: changing name in nortel T7316E handset
instructions are toward the bottom of this page:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Posted on Aug 26, 2008
consultel1
  • 860 Answers
SOURCE: How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
Posted on Feb 09, 2009
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
ynotphone
  • 192 Answers
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Posted on Mar 19, 2009
ynotphone
  • 192 Answers
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Mar 25, 2009
How do I set up a voice mail with a Nortel M3904?
This is dependent on you being able to access your voicemail mailbox (a mailbox has been setup for you by the administrator and you know the codes to login to your mailbox). Go to your voicemail which should be:
  1. press the message key.
  2. Enter your mailbox number, then press #
  3. Enter your password, then press #. (if you don't know this then you will have to contact the administrator for the telephone system)
When logged into this:
  1. press 82.
  2. Press 1 for external greeting, 2 for internal greeting, 3 for temporary greeting, or 9 for Personal Verification (spoken name)
  3. Press 5 to record then wait for tone.
  4. Press # to end recording
  5. Press 2 to listen to the greeting
  6. Press 76 then 5 to delete the greeting and re-record it.
  7. Press 4 to return to your messages.
Nov 24, 2014 | Nortel Networks Meridian M3904 Corded...
We have a Nortel T7316E and I am trying to access the Auto Attendant via the CCR Tree to change the second greeting after our main greeting. For Example: When calls come in and the AA picks up there is a...
Choose Other, CCR, ADMIN, Enter 1 for CCR tree one and when the option for "Path" appears press 0 and you will have the option to record. I believe there is an option for "More" which you select and play the greeting if not you can choose rec and the option to play the current greeting will be on the screen.
Jul 15, 2014 | Nortel Networks T7316E Telephone Platinum...
How do I change voicemail greeting on Nortel Model T7316 phone?
feature 981
enter password
listen for promt to change greeting.
for main greeting
press feature 983
if 3 digit extensions enter 1020000 if 2 digit extensions enter 120000
press AA
press grtg
press 1
press rec
press ok to end recording
press ok
press rls
To Listen to the Greeting, press Play. To ReRecord, press RETRY. Press OK to accept Greeting.
Jan 11, 2011 | Nortel Lands Phones
T7316 Change recording of Company Directory
To re-record the main greeting on most Nortel voicemails, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Jun 07, 2010 | NorStar T7316E Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
How to remove the old corporate greeting in T7316 Nortel?
Press Feature 983 enter admin password
press AA
press Grtg
press Grtg again
press 1 then ok.
Greeting 1 is usually for day and 2 is usually for night depending on the tech who set it up.
May 17, 2009 | Nortel T7316E 2-Line Corded Phone
How do I change my mailbox to an information mailbox?
Changing a mailbox from a subscriber mailbox to an information mailbox would require you to delete one in favor of the other but, if you want to temporarily disable the message taking ability you could login to the mailbox, press the admin key, press the greeting key, press the choose key, select alternate greeting, when you choose your alternate greeting mailbox youll be asked if your mailbox should accept messages press the chng key to toggle from yes to no. dont forget to record a alternate greeting for the mailbox.
hope that helps
Mar 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Change voice message on nortel meridian phone system
You need to go in to voice mail admin .
Feature 983 1020000
press AA
press Greeting
press greeting again
enter 1 for greeting 1
this should be your main greeting it could any greeting from 1- 20 , it depends on how it was set up but that should work fine .
Feb 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
I can't change the main greeting for our office line..
Unfortunately, Office systems are all controlled by a central system that requires an administrator to make changes such as recording the system answer menu, creating menu systems, etc. This is usually done by the I.T. department or private contractor. Sounds like maybe you have a gap in personnel. If that's the case, you'll need to call Nortel for support. Thanks for using Fixya!
Jan 27, 2009 | NorStar T7316E Corded Phone
Nortel Compact ICS 4
Hi Yolanda,
You did not mension what type of voicemail you have installed with the phone system so I'm assuming it is also a Norstar.
To record your Primary Greeting:
1. Press " Feature 9 8 1 "
2. Enter your password ( Default is 0000 )
3. Press " OK or * "
4. Press " Admin or 8 "
5. Press " Greet or 2 "
6. Press " Record or 1 "
7 Press " Prime or 1 "
Display should read " Record new ? "
8 Press " Yes "
Display shows " Record Greeting : "
9. At the tone record your Greeting
10. Press " OK or # " to end recording
Jul 25, 2008 | Lands Phones
NorStar T7316E Corded Phone Logo
112 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
