You will need to remove the drain plug cap and look inside the drain pump.Open the little access door on the front of the machine and unscrew the cap.there will be water that comes out so keep a few towels or shop vac close by.
once you remove the cap check for obstructions and clear them if you do not find any you may need to remove the whole front panel and take the drain boot off the bottom of the tub and look there as well.
