1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
SOURCE: ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
SOURCE: Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
SOURCE: error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
SC422 PCC leak - Timing & Condition -
When the current leak is
detected for 2 seconds,
and the leak detection
started 1 second after the
PCC turned on. This leak
signal is monitored twice a
second. If it is detected
twice in a row, this SC is
displayed.
• PCC unit not properly
installed
• Broken corona wire
• Defective high voltage
supply board
(T1/PCC/BR)
board
board
