SOURCE: electrolux ew 880 f. Working
Disconnect the power supply for few minutes, say 15 minutes and then turn it on. This would reset the machine.If the problem persists, this would more likely confirm an internal issue and needs repair.If you wanted to repair it, kindly provide few more details :-
1. How old is the machine?
2. Any error message on the display?
3. Any sequence of beeps like 3 beeps, then pause and then 3 beeps or is it beeping continuously?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
