Computers & Internet Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When trying to connect to wireless network at home it asks for router pin then tries to set up new network. I want to connect to exsisting network
Amit Awasthi
Level 2:
Scholar:
  • Expert 89 Answers
  • Posted on Jan 29, 2011
Amit Awasthi
Expert
Level 2:
Scholar:
Answers
89
Questions
Helped
23916
Points
169
My friend,
Where it says for a pin .there is option below that screen "I want to enter passphrase"
Please select the option and enter your wireless network key.
You will be connected to the existing network when you will enter the key.
Regards:-
Amit
When i try to set up my new 3g mobile bbroadband wireless-n router the computer ask me for a pin number that sopposed to be in the back of the router and already try all the numbers that i can found and it...
This is a common issue with Windows 7. To get around this issue, try the following steps.
  • Click the Network icon, located on the right of the taskbar near the time. It should look like a computer monitor.
  • Locate the Wireless network you want to connect to and highlight it and click connect.
  • At this point you should be given two options: "Setup the Network connection now" or "No, connect to the network anyhow.
You want to select the option for "No, connect to the network anyhow"
  • This will bypass the requirement of a PIN, which is not supplied with these routers.
asked for PIN when connecting to wireless network What should do
I cant figure out where the pin number
Are you trying to connect to the wireless network on a WINDOWS VISTA / 7 computer? Sometimes on the windows vista computer , it will ask you for the PIN number when you try to connect to the wireless network. On the same window at the bottom you will find the option " I want to connect to the network or I want to enter the key manually". If you click on that option , it will ask you for the security key.
If you don't know the security key, then you will need to check the settings of the router. You will need to open the router set up page where you can check all the wireless settings of teh router. If you want, you can also find the PIN on the wireless settings page of the router.
If you are trying to connect any other wireless device to the network and it is asking you for the PIN then you will need to open the set up page of the router and under wireless settings you will find PIN.
Click here for step by step instructions
Im trying to find my belkin pin number so i can have internet in my new laptop,...where can i find this?
2answers
Fogotten security pin
1helpful
I need to no my 8 diget pin on my belkin router and it is not on the router
key.
find PIN.
2answers
We just added a second laptop to our home network and in setting up the laptop for wireless it asked for a pin number for our linksys wireless router but the pin number is not on the unit and we don't have...
Yes this is very straight forward
open internet explorer on your computer which is connected to wireless router.
browse to your gateway address. The default for linksys is usually http://192.168.1.1
then it will ask for username and password
linksys default username: (leave this blank)
linksys default password: admin
if that doesn't work try username: admin
password: admin
Once logged into console you should be able to see wireless security settings
Click on that and it will take you through to a page with your security settings on there you will see a wireless key or network key or wireless passphrase.
simply make a note of the key as its written. (If the password is masked or *********** out ) which is the case on some of the newer linksys devices you can simply overtype the password with a new one, bear in mind that you will have to then update any clients that normally connect to the wireless network with the new password. So thats all computers, laptops, DS's Wii's Playstations & Xbox's.
******I'd STRONGLY recommend you DO NOT change the wireless password / security key over wireless you should always do it using an RJ45 ETHERNET cable connected to your computer and the router. *********
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Can't remember my pin number
key.
Click here for more information about the router
and network
I want to add a wireless laptop to my exsisting broadband moderm
Hello...you can find your network key within your router settings.
Here's a rough guide:
1. Type your router IP address, eg http://192.168.0.1 or whatever is correct for your model, into a web browser address bar
2. Enter your router username and/or password at the prompt. The defaults for D-Link are username: admin and password left blank: but if you have set a router password/username, please enter these.
3. In the router user interface, go to the section headed Home > Wireless. Your network key will be here, labelled Pre-shared key or similar.
This Dlink tutorial has some helpful screenshots.
Hope this helps; however, please come back to Fixya if this doesn't work or if you need more information.
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
