Optoma EP1690 DLP Projector Logo
Posted on Jan 21, 2011
Hi, I have an Optoma 1690 which has strobing - standby/on, temp and lamp lights. This happens as soon as it is plugged into power. Then after doing this for about 5 min, on the stanby light flashes once a second. All lights strobing, then only standy light flashes. What is the meaning of this please. Max
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
746
Points
I also problemma which has strobing - standby/on, temp and lamp lights.This happens as soon as it is plugged into power.
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
http://www.myprojectorlamps.co.uk/projector-manual/Optoma/EP1690.html
Good luck
2answers
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
2answers
Powers on but no lamp light
Did you find a solution to this problem? I have the same thing with my Optima 1690...
5helpful
2answers
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
2answers
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
